Amature using psu calculators
Go to solution Solved by W-L,
2 minutes ago, dickmaurer said:
-SNIP-
That system wouldn't draw more than 350W so a good quality 400-450W would be more than capable of powering all of that.
I've been playing with psu calculators and they all seem to give a different numbers. I've gotten numbers from 300-650 watts! Could someone recommend a reliable calculator?
Also I've heard that it's best to buy a power supply about 100 watts over what you really need for efficiency reasons. Do I add this number to what the calculator spits out or does it factor in this number on its own? Thanks:)
https://linustechtips.com/topic/554410-amature-using-psu-calculators/
I usually use PCPartPicker. It's still slightly over but it's one of the more accurate ones.
What are your specs?
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
What's the specs?
For (most) single GPU setups, 550w is enough.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
Nothing out there is really that good that I've seen, what is your component list we can give you a more accurate value than what the calculators can do.
This build is still in the planning stages but this is what im going to get:
atx motherboard
4gig gtx960 strix
dual channel 8gig ram
generic hard drive
generic ssd
bluray drive
fx 6300 cpu
4fans counting cpu fan
various leds integrated into the case
The specs of the part should tell you the demand, add them up multiply by 1.3 and round up to the nearest psu available.
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
You gotta share dem specs and I'll spit out an estimate of how much power it will use and will give you a good PSU estimation for your budget!
