Sponsorship Help
Go to solution Solved by S1lent_5am,
the chances of getting company sponsorships out of the blue for a one off build is going to be very very low and the only way to find out is to ask. But the best way to get sponsorships would be continue to do quality builds, get your name out into the modding community and enter some build competitions you don't have to win but it does help after awhile companies will see value in your work but till then just keep building even if it has to be done with older parts, just keep building.
4 minutes ago, HeroXLazer said:
I'm planning a modded pc build in a briefcase with monitor, how do you think I can  get a sponsorship?
You can't just get sponsored for a build because you want to. Best you'll get from a company is some stickers if you haven't had any good previous builds using their parts.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/551947-sponsorship-help/#findComment-7282238
lol you're not gonna get a sponsorship
thats not how it works
https://linustechtips.com/topic/551947-sponsorship-help/#findComment-7282239
Lol hahha. Am going to build a guitar PC does I get a sponsorship now?
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/551947-sponsorship-help/#findComment-7282246
yay free stickers much better than getting computer components
https://linustechtips.com/topic/551947-sponsorship-help/#findComment-7282266
https://linustechtips.com/topic/551947-sponsorship-help/#findComment-7282408
