Can i respray my Noctua NF-F12 fan?!!?!?
MLG_Matti6005
So i have 4 Noctua NF-F12's but my pc is a all white build... i HATE!!! the colour of the Noctua fans... i keep hearing Linus saying that they are "the best fan" soo i decided to buy some.. BUT!    can i respray them using spray paint to make it a different colour!?!? will that change the performance or will it ruin it??? please tell me and if someone has done this please tell me if it changed anything :D   Thanks.
It would completely ruin them!
See my Build here!
Intel 6700k -  Strix GTX 1080Ti - Corsair AX760 - Corsair Dominator 16GB 3000MHz - ASUS Maximus VIII Hero
Seagate Barracuda 1TB -  Samsung 120GB 840 - Samsung 840 EVO 250GB - Corsair H100i - Corsair Air 540 White -
Corsair AF120 - 2x Noctua NF-F12 - 3 x Noctua NF-S12
 Dell S2417DG - Dell UH2515H
I'll give the same answer I've given at least 100 times for the same question: painting fains will, in 9/10 cases, either break then or make them inefficient.
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
OK well.. i guess that was the case... but if i respray the housing.. is that ok??
They may be fine for a while, but because paint adds a layer of colour which adds weight, they will usually come out uneven, therefore overtime damaging the bearings and motor leading to a premature death.
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
1 minute ago, MLG_Matti6005 said:
or maybe the rubber gromits???
The housing is still what channels airflow so will still affect it and the rubber bits would not be a good surface for paint to adhere to and uou would end up with a cracked paint mess that would end up in your system!
See my Build here!
The LinusTechTips special have a nicer colour. Its black with orange rubber grommets.
OH YEAH! i forgot about those... yes thanks man!
.... where can i buy them!!
You can also buy different colours of their rubber grommets. And they also make an industrial version of the nf f12 which is black with brown rubber grommets.
EDIT: 500th post xD
Written on my Lenovo Z500 T - I5-3230M   Or
My pc :)
I wouldn't suggest painting the fins but I think painting the outer housing wouldn't hurt. I mean it doesn't move
Longboarders/ skaters message me!
If you want black Noctua fans, get the LTT edition, the PPC Industrial or Redux models.
Don't break $30 fans because you don't like their colour
i believe you can dye them if you mask off the fan housing well. I remember I was able to dye the nfp12 but the fan was more or less removable.
Silverstone FT-05: 8 Broadwell Xeon (6900k soon), Asus X99 A, Asus GTX 1070, 1tb Samsung 850 pro, NH-D15
Resist!
