Hey Forum
In a couple months I will be buying a Curved 34" 3440x1440p Ultrawide monitor that runs at 75hz. Right now I have one EVGA GeForce GTX 970 4GB FTW Edition card which is an absolute beast but I'm only running a 1920x1080 monitor. I'm just wondering and curious to whether or not throwing in another card in SLI will be enough to handle the workload. Thanks for the help!
https://linustechtips.com/topic/549508-will-970-sli-be-enough/
@ 75... single GPU should be fine, but if you got a 100Hz+ monitor... I'd say SLI or DIE!
Spartan 1.0
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor
CPU Cooler: Cooler Master Seidon 120XL 86.2 CFM Liquid CPU Cooler
Motherboard: Asus Maximus VI Extreme ATX LGA1150 Motherboard
Memory: Corsair Dominator 32GB (4 x 8GB) DDR3-1600 Memory
Storage: OCZ Vector Series 512GB 2.5" Solid State Drive
Storage: Seagate Desktop HDD 4TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 980 4GB Classified ACX 2.0 Video Card
Case: Thermaltake Urban S41 ATX Mid Tower Case
Power Supply: Corsair 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply
Optical Drive: LG BH16NS40 Blu-Ray/DVD/CD Writer
Optical Drive: LG BH10LS30 Blu-Ray/DVD/CD Writer
Operating System: Microsoft Windows 10 Pro 64-bit
Sound Card: Creative Labs ZXR 24-bit 192 KHz Sound Card
Monitor: 2x Asus VG278HE 27.0" 144Hz Monitor
Keyboard: Logitech G19s Wired Gaming Keyboard
Keyboard: Razer Orbweaver Elite Mechanical Gaming Keypad Wired Gaming Keyboard
Mouse: Logitech G700s Wireless Laser Mouse
Headphones: Creative Labs EVO ZxR 7.1 Channel  Headset
Speakers: Creative Labs GigaWorks T40 Series II 32W 2ch Speakers
Hades 1.0
Laptop: Dell Alienware 15 2015
CPU: i7-4720HQ CPU
Memory: 16GB DDR3 SODIMM RAM
Storage: 256GB M.2 SSD
Storage: 1TB 5400rpm 2.5" HDD
Screen: 15.6" FHD Display
Video Card: Nvidia GTX 970M with 3GB
Operating System: Windows 10 Pro
Project: Spartan 1.2 PLEASE SUPPORT ME NEW CHANNEL > Tech Inquisition
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256192
3 minutes ago, cheshgoalie21 said:
Hey Forum
Depends...what games, settings, target fps...
|[ i7 6700k ][ MSI z170a XPower Gaming Titanium MB ][ 16gig G.Skill Trident Z 3000mhz ][ Gigabyte Xtreme GTX 980ti ][ Samsung Evo & Intel SSDs ][ Corsair 540 air ][ XFX Pro 750w Platinum ][ 24" Asus 144hz ]|
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256199
Single card at 3440x1440 75Hz? No, at 1080P sure.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256206
I'm going to college for computer science, programming and such, I also do dabble with some graphic design (illustrator/Photoshop) here and there but its just for fun. Adding to that I also game a lot, mostly playing CS:GO, ARMA 3, Battlefield 4, GTA V, Fallout 4, and other titles like that. If you have anymore questions just ask.
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256249
16 minutes ago, Savir said:
Depends on the games/tasks you will be doing. I would personally sell the GTX 970 and buy a GTX 980ti. SLI can be glitchy in some games. But SLI should perform decently on most games
In the post above I specify what I primarily do and what I will be mostly doing in the future. But I feel like I would only be able to get like $250 if not less for the card since i've had it for over a year and it would cost me more to get the 980ti when in the tests I've seen the 970 SLI has done better than a single 980ti, so that's just what my thought process is. Tell me what you think, thanks!
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256256
Fellow computer science student. Honestly I wouldn't SLI the 970 if you plan on running 1440. That really needs more VRAM if you want the setup to last. My advice is sell the 970 and get a 980ti.
If anyone asks you never saw me.
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256262
Here's a 970 SLI setup up against a bunch of high end cards, including some AMD offerings.
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256267
Well yes it depends on how much you can sell it for. The GTX 970 when SLIed still only has 3.5/4 gb of Vram which can be limiting. This is why I would prefer the GTX 980ti, which has 6gb. And in the future if you want to upgrade your screwed if you have 2 GTX 970s. On the other hand, when you need more performance you can get a 2nd 980ti. You may spend more now, but it will pay off in the future.
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256273
Cost to keep your current 970 and buy another = ~$330 = ~60 to 70 fps in 4k best case
Cost to get a good 980ti = $680 - $250 = $430 = ~50 to 70 fps in 4k AND reliable, more usable RAM, less power, less glitches / better support, better upgrade potential
Is the $100 worth it? Your call...
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256302
Probably should mention that I will be upgrading to pascal in October when I get the money from my birthday/ with money saved up and most likely SLIing that, but that's of course only if it's out by then which I think its rumored to be out by the end of the summer anyway. But the 970 in SLI should hold me over till then right? Also Low_Battery you say 4K but I thought 4k was 3840×2160, I'm only really looking to game at 3440x1440.
Just for haha's where would be the best place for me to sell my 970, ebay?
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256340
Honestly I would just wait for Pascal/Polaris. You said you are getting the monitor in a couple months? The new GPUs will be out and other people will look to buy last gen cards. Then you can get a 1080ti or what ever it's called. Just save some extra money to give yourself some options. Be patient and it might pay off.
Edited by Savir
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256357
Then I have good news. In October when the new cards release DX12 should be implemented to a greater degree, this means gone are the limitations of SLI and Crossfire. So you can have a 980ti and the new 1080, or a Furyx2 if you want. All it takes is DX12 compatibility and the 980ti has it, the 970 to a lesser extent.
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256358
The numbers are not exact, just a way to give a rough comparison.  There are way too many variables involved to give an accurate specific average.
Ultimately you will be fine either rout, and the differences don't really matter much given the short time frame before upgrading again.  Also, if you are upgrading to pascal regardless, you also need to factor in what the best resell would be: 2 970s or 1 980ti.
In regards to where to sell, just look and see what the prices and competition are on either site. It has a lot to do with what else is posted.  Ebay gives you a wider audience, but also potentially more competition.  You can also look at tech forums that have classified options. I prefer CL, but don't know that it is best per se...
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256388
Also remember the risk of selling on Ebay. Any customer can take delivery, do what they want to the card, and claim you sold it to them in that condition. Why I stopped using Ebay, one too many cases like that. Hopefully Linus gets the classifieds back up soon here, that was a great way to sell parts.
Also, how far are you in your program, are you to Boolean algebra? Can always use another person to work through problems with :)
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256405
I excel in 10th grade geometry.
  • CPU: Intel Core i7-6700k @4.3ghz, Motherboard: Gigabyte Z170X Gaming 7, RAM: Corsair Vengeance LPX 16GB @2400mhz, GPU: Gigabyte GTX 1080 G1 , Case: Corsair 300R, Storage: Samsung 850 EVO 256GB SSD, WD 1TB Black HDD, WD 2TB HDD PSU: Evga SuperNova 750 G2, Display: ASUS VG248QE @144hz, Cooling: Cooler Master V8 GTS, Keyboard: Corsair K95 RGB Platinum, Mouse: Logitech G502 Lightspeed, Sound: Phillips SHP9500 + VModa Boom Pro, Operating System: Windows 10 Pro
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7256692
xD get ready to eat, sleep, and breathe math. My midterm coming up has 5-6 problems and I have two hours to complete them. If you go engineering like me it's way worse than a BA though.
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7258740
If you plan to game on an ultrawide 1440p then you'll want 2 980TIs unless you're good with turning down the settings. Even then, you'll run into issues with VRAM. Especially since the 970 basically has 3.5gb VRAM.
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7259161
I'm a senior in high school and will be going to the College of Saint Rose next for their dual degree program for programming and information technology which will let me get my masters in 5 years. Right now I'm in a basic programming class where we are starting out with some simple python stuff. But I'm looking forward to college big time!
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7260208
I'd buy the second 970 then and wait for the cut down GP100 chips (eg 80Ti) in 2017 or so when going to Pascal instead of buying the GP104 chips (eg, 70/80) that are likely to come out this year. 970 SLI should handle 3440x1440 high.
https://linustechtips.com/topic/549508-will-970-sli-be-enough/#findComment-7260316
