3 minutes ago, connorW said:
Iv got £500 ($700) budget for a pc build and need ideas, I want the i5 4690k as the CPU for upgradability HELP guys
Do you need an OS? Keyboard and mouse? Monitor?
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
6 minutes ago, connorW said:
Just the OS iv got the peripherals
http://pcpartpicker.com/p/yGpFcf
 Look on: https://www.reddit.com/r/microsoftsoftwareswap/ for the OS.
Stille (Desktop)
Evoo Gaming 15"
Okay, this is the best I could do. Notice though, that you'd usually be much better off with a smaller CPU and a faster video card. If you wanted to go with something like that, you'd have to get a Windows 10 key from Kinguin or G2A.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core OEM/Tray Processor  (£195.59 @ Overclockers.co.uk)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  (£19.99 @ Amazon UK)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  (£65.99 @ Ebuyer)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1866 Memory  (£31.98 @ Amazon UK)
Storage: OCZ Trion 100 240GB 2.5" Solid State Drive  (£45.99 @ Amazon UK)
Video Card: PowerColor Radeon R7 370 2GB PCS+ Video Card  (£109.03 @ More Computers)
Case: BitFenix Neos Black ATX Mid Tower Case  (£32.99 @ Novatech)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (£44.17 @ Amazon UK)
Total: £545.73
Generated by PCPartPicker 2016-02-15 18:42 GMT+0000
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£185.96 @ Amazon UK)
Motherboard: ASRock H81M-HDS Micro ATX LGA1150 Motherboard  (£41.64 @ Amazon UK)
Memory: Crucial 8GB (2 x 4GB) DDR3-1600 Memory  (£34.76 @ More Computers)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  (£34.98 @ Amazon UK)
Video Card: MSI GeForce GTX 750 Ti 2GB Video Card  (£89.99 @ Novatech)
Case: Corsair Carbide Series 88R MicroATX Mid Tower Case  (£37.99 @ Amazon UK)
Power Supply: Super Flower Golden Green HX 450W 80+ Gold Certified ATX Power Supply  (£59.30 @ Amazon UK)
Optical Drive: Samsung SH-118CB/BEBE DVD/CD Drive  (£8.75 @ Amazon UK)
Total: £493.37
Generated by PCPartPicker 2016-02-15 18:46 GMT+0000
This should serve you well, you can get windows 10 keys cheap just look Ebay, reddit…. I s the i5 4690k overboard? You don't need optical drive either.
Total: £545.73
That's not a good PSU check this: http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
And you are spending a lot on the CPU and very little on the GPU, that's not balanced. Get a i3 6100 and a better GOU.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
2 minutes ago, mcraftax said:
http://uk.pcpartpicker.com/p/QFRC3C
Same as the one above, and why a k processor with a H81M board?
Just now, Matty2hatty said:
Realisticly why would you even try to OC a 4690k on a £500 budget?
Exactly! You will get a unbalanced system like that. I will cook up a build soon.
Look, I'm just trying to make a build that includes his beloved CPU. I even specifically told him that a build like that doesn't make much sense. But I'm guessing (wildly so) that he is one of those CS:GO youngsters that want those i5s and i7s to hit stable 300 fps on low resolutions.
Calm down, he could just not have the knowledge.
Here you go, this a decent balanced build there is no need for a i5 at this budget, especially a haswell one. Get a Skylake i5 so you can game well now and if you need to upgarde no problem the i5 won't bottleneck anything!
If this is off budget get a 950
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  (£149.96 @ More Computers)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard  (£42.98 @ Novatech)
Memory: Crucial 8GB (2 x 4GB) DDR4-2133 Memory  (£31.98 @ Ebuyer)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£37.98 @ Novatech)
Video Card: Asus Radeon R9 380 4GB Video Card  (£169.99 @ Novatech)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  (£28.49 @ Novatech)
Power Supply: Super Flower Golden Green HX 550W 80+ Gold Certified ATX Power Supply  (£63.48 @ Aria PC)
Total: £524.86
Generated by PCPartPicker 2016-02-15 18:56 GMT+0000
Get the OS from microsoftswap
Edited by Castdeath97
Fixed the power supply
Video Card: Gigabyte Radeon R9 380 4GB SOC Video Card  (£174.96 @ More Computers)
Power Supply: XFX TS 430W 80+ Bronze Certified ATX Power Supply  (£34.68 @ Aria PC)
Total: £498.03
Generated by PCPartPicker 2016-02-15 19:00 GMT+0000
better?
