ITS ALL GOING TO MY SSD! PLEASE HELP
Solved by SaladFingers,
1 minute ago, Made In Canada said:don't know how to, I will just look it up, thank you though.
also, it said something about how my SSD was my "main partition" while my HDD is "unallocated", any idea what that means and if I can make it so stuff will download to my HDD, or at least ask which one to download to?
Yes, that's why I wanted the screenshot. Right click on that "Unallocated Space" on the HDD and choose "New Simple Volume" and follow the steps.
This is how you then set your HDD to be the default storage for your Downloads (you can do the same for documents, pictures, videos, etc):
23 minutes ago, SaladFingers said:Right click on your downloads folder -> properties -> location -> change default to your HDD
