HeyGuys
I finally decided on what to do with my PC in terms of the custom water loop. (I was planning on changing the color scheme to white/black, but that would cost me a fortune so I'm sticking with the green/black I have at this moment)
Current list of components:
CPU-block // GPU-block // 240mm rad // Fittings (8) // Tubes (1m) // Liquid (1L) // Res+pump // backplate GPU
Total price: €444.47
Some questions:
- With the CPU & GPU blocks there's thermal compound included, is this good one or do I need to buy separate (possibly better) compound?
- I only have a 240mm rad to go on the top of my H440 now. I plan on doing some heavy overclocking on both the GPU and CPU. Do I need another 120mm rad to go on the back on my pc?
- Do I have enough fittings?
- Do I have enough Liquid coolant?
- Do I have enough tubes?
Any help & remarks are greatly appreciated :)
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/545681-water-loop-newbie-questions/
240 rad with i7 and 780ti seems a bit too small for the rad since you also want to OC
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
So you'd throw in an extra 120mm rad?
5 minutes ago, yannickverc said:
-SNIP-
That looks like a good start, one thing I would recommend is more rad space since you are at the absolute bare minimum of 120mm rads per component. Ideallly if you can squeeze in a 360mm rad that would be great. For fittings and tubing you have the correct amount, if you do have the option though go with thick walled 3/8"ID 5/8" OD  it doesn't kink easily like thin walled tube, and I think your might be cutting it eryclose at 1M but 2M should be more than enough.
I usually do 120mm of rad per Core (ram blocks and Chipsets don't count) component and then an extra 120-240mm for overclocking depending on how hard you want to go.
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
This seems a bit much but I guess it doesn't hurt^^
1 minute ago, ITheSpazI said:
I usually do 120mm of rad per component and then an extra 120-240mm for overclocking depending on how hard you want to go.
Yea I think I can fit in a 360mm rad on the top of my case. Would that be a better option than 240 + 120 ? (For leaking points etc)
oh it is =P, But i usally have amd stuff, this is my first intel system and my loop is so overkill now
Compression fitting are pretty reliable now so as long as you use those i wouldn't really be too worried about leaking
360 would be good, just make sure there is room for rad +fans+ motherboard up there
14 minutes ago, yannickverc said:
Some questions:
2
There is little performance difference between compounds regardless, I wouldnt worry about it.
For Heavy OC I would definitly go triple that (6x 120). With a 240 I would keep it close to stock
Yes, but I would get some extras if I was you. Its a shame to find out one is leaking and you need to postpone the project till ur RMA comes back. Plus filling etc. is eaier with a few extra fittings.
Your cutting it close at 1L, get like 2 to be sure
If your runs are short yeah.... Getting some extra doesnt hurt. I went with 3m the first loop I did.
Just now, ITheSpazI said:
-snip
Good points there, thanks!
Longer rads tend to do a bit better than a bunch of shorter rads all together, and for leaks the lesser number of connections means less points of failure.
Yea, that's what I'm worrying about too.
