Hello, this is my first post on the forums. what should i purchase, a noctua cpu cooler or the new eclipse p400 case. after upgrading my graphics card from a gt 730 to a r9 390, i have been playing games at higher resolution and now my stock cooler is starting to sound like a jet turbine while playing games like fallout 4 and battlefront at ultra. i cant decide, i can buy the new case and sell my old one and use that money to buy a cooler, but will not be as good. or just stay with my currant case and buy the cooler. i am also planing on overclocking. my budget for the cooler is $70 - $80 and the case falls into that budget as well at $70. heres my build:
fx 8320 3.5ghz
asrock 970m pro3
2x4gb gskill ripjaws x
evga 600B 600w psu
powercolor pcs+ r9 390
sandisk plus 120gb ssd for boot
random 250gb hdd for mass
random 120gb hdd for mass (downloads, music, videos, pictures)
thermaltake core v21 mid tower case
https://linustechtips.com/topic/544609-cpu-cooler-or-case/
a new cpu cooler
i'd suggest a CRYORIG H7 or R1
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/544609-cpu-cooler-or-case/#findComment-7204053
Have you tried lowering fan speeds?
https://linustechtips.com/topic/544609-cpu-cooler-or-case/#findComment-7204945
Don't cheap out on your cooler just to afford a better case right now. Get a good cooler and it will serve you well for a long time. I use the Dark Rock 3 myself and I highly recommend it. Both cool and quiet. It DOES have RAM clearance issues but you should be fine with 2 sticks. Worst case you put the fan in pull. Or splurge for the Pro 3 if you have room in your case/your memory allows it.
The Dark Rock 3 was $95 CAD on NCIX last I checked.
https://linustechtips.com/topic/544609-cpu-cooler-or-case/#findComment-7205910
How quiet is it? I looked it up and its on sale at newegg for 60.
https://linustechtips.com/topic/544609-cpu-cooler-or-case/#findComment-7206844
I'd up your budget $10 and get an NH-D15. It's the best air cooler on the market, it's quiet as hell, Noctua coolers are insanely easy to mount, you get a five year warranty, they give you the parts to mount to new sockets in the future, you're getting two top of the line fans, I mean if you're going big at $70-$80 might as well go really big for $90 for a heatsink that will last you forever and will be easy to install and uninstall.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608045
https://linustechtips.com/topic/544609-cpu-cooler-or-case/#findComment-7207146
If you leave the stock fan on the heatsink it maxes out at 21db, but only with the fan pinned at 100%. If you want to change it you can though, mounting hardware fits 120mm fans. I don't hear anything under normal use, and even when my CPU is at 100% load it is still quiet.
https://linustechtips.com/topic/544609-cpu-cooler-or-case/#findComment-7209808
Ok. I decided that i will get eather a cryorig h5, h7, or the be quiet dark rock 3. But i have one more question. Can a 160mm cooler fit in a case with a cpu cooler hight limit of 160mm? Will i be able to close the pannel without scratching it?
https://linustechtips.com/topic/544609-cpu-cooler-or-case/#findComment-7212512
Yes it would fit, measurements are almost always on the generous side.
What kind of dollars are you using?
https://linustechtips.com/topic/544609-cpu-cooler-or-case/#findComment-7213395
Just now, carlospicywiener said:
What do you mean by dollars im using?
USD, NZD, AUD, etc.
https://linustechtips.com/topic/544609-cpu-cooler-or-case/#findComment-7213475
7 minutes ago, carlospicywiener said:
Oh, USD
Depending on how much you want to spend, here are some good options:
H7: http://pcpartpicker.com/part/cryorig-cpu-cooler-h7
Pure Rock: http://pcpartpicker.com/part/be-quiet-cpu-cooler-bk009
Kotetsu: http://pcpartpicker.com/part/scythe-cpu-cooler-scktt1000
Macho Rev. B: http://pcpartpicker.com/part/thermalright-cpu-cooler-machorevb
https://linustechtips.com/topic/544609-cpu-cooler-or-case/#findComment-7213563
