Hello guys,
So im 15 and i lovve eletronic and particulary robots so i would like to know if someone could help to find a good robot for me that isnt expensive (not more than 100 box) and that help me to learn programming but isnt like programming for little childrens. It should start simple programming with blocks then i finish in c or c++. Its progressive if you see what i mean.
Thanks for help
https://linustechtips.com/topic/543166-robot-for-learning-programming/
its called an arduino
and you can make it anything you want, not just a robot :)
All you can learn about C++ in robotics is syntax and standard language features along with... its use in robotics. Don't think that by programming some robotic things you will learn how to write a game engine for example. It can make it easier tho.
If you don't want the "kids stuff" with stuff like Scratch, then you need to do it the hard way with before-mentioned Arduino for example.
