Stay with powerline adapter out go WiFi?
EastPhilly
I original built my computer without a WiFi adapter to save money and get better speeds by using the powerline adapter. My only problem is my house is kind of old, so the wiring may not be great.
Multiple times per day my internet connection will disconnect, but the icon in the lower right of the computer will say connected. Right before I am able to connect again the icon will show the yellow triangle for a second and then disappear as it reconnects to the internet.
This had happened will u was using Comcast as well as Verizon. Furthermore the WiFi in my phone still works whole my pc doesn't.
Should I switch to WiFi? We already have between 2-6 devices connected at a time through WiFi, so a word connection is preferred. The only problem is the people who renovated our house before we started living here never put in a single phone line or cat5 line. So WiFi and powerline are my only options.
Thanks for any advice!
i currently have a power-line connection with wireless as a backup (i.e. if my connection cuts out i disable the power-line connection and try the wireless, if it still can't connect then the problem isn't on my end and generally i need to reset the modem). I wouldn't say completely ditch power-line.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
Every time you have to jump a circuit breaker via power-line you lose A LOT of signal strength, so selecting the right outlets can make a huge difference.
Also, running wireless even in an old home isn't a hard thing to do (in fact it's generally much easier in old homes than new ones since they tend to have easier access to panels, floorboards, and less insulation.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
