Under estimating system requirements.
I was checking out some system requirements for a game earlier and it got me thinking about the time I tried to run Border lands 2 on a geforce 6800gs
The min requirements called for a geforce 8500. I figured a couple generation difference wouldn't kill it and it was a high end 6000 card.
It was chugging alone around 30 okay, dipping no lower than 25(not okay) until I got to the first real fight and it actually crashed my computer after dropping below 10 frames. Have any of you tried something like that?
https://linustechtips.com/topic/534144-under-estimating-system-requirements/
usually, you want to meet the recommended specs, not the minimum ;)
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
yes with spore when it first came out, because you needed a 256mb graphics card, and then a decent one that wouldn't make blue/green/pink textured, textures.
now I play it at 4k and it looks funny....
It probably shouldn't have crashed unless it was overheating or unstable.
Yeah I've tried playing all sorts of games on laptop GPUs and integrated graphics.
Got GTA 5 running at 1024x768 on a 610m at 30FPS. Looked pretty awful, but definitely playable.
Tried playing Crysis 1 on pretty much everything I've owned.
 Almost as cool as my temps
Probably wouldve figured that now
I've tried all sorts of stuff on integrated. Tried to get saints row 2 to run on an E-Serious laptop apu
No luck
With tweaking the OS and game... you would be really surprised.
Bioshock Infinite Ultra at 480p on a DDR2 4570m laptop anyone?
CONSOLE KILLER: Pentium III 700mhz . 512MB RAM . 3DFX VOODOO 3 SLi
I remember playing loads of games on a Pentium P6100. UE is the best engine for low spec players, highly tweak-able.
Then there are games that give you little to nothing.
https://www.youtube.com/watch?v=1OMxH7KCFRY
Mid-range Emulation Gaming and Video Rendering PC
[CPU] i7 4790k 4.7GHz & 1.233v Delidded w/ CLU & vice method [Cooling] Corsair H100i [Mobo] Asus Z97-A [GPU] MSI GTX 1070 SeaHawk X[RAM] G.Skill TridentX 2400 9-11-11-30 CR1 [PSU] Corsair 750M
I've tried a couple games on my Core 2 Duo + Intel GMA graphics. It was not fun.
A Guide For Getting Started With Linux
My first rig:   CPU: AMD Athlon X4 860k Cooler: Cooler Master Hyper T4 MoBo: Gigabyte GA-F2A88XM-DH3 Video Card: EVGA GTX 750 Ti Superclocked RAM: 8GB Kingston HyperX Fury White 1866MHz Storage: WD Blue 1TB PSU: EVGA 100-W1-0500-KR Case: Rosewill SRM-01
Teach me your fucking ways.
I tried that out with a laptop
Played a lot of halo combat evolved and painkiller
TES III: Morrowind was about the best I could run and it crashed after ~15 minutes :P
I used to play all my games on a core i3 2310M, Intel HD 3000 and 3gb ram. Ran everything at minimum settings 720p and got at most 30 fps. Never had anything that was unplayable though. This was games as demanding as skyrim, borderlands 2, and Bioshock infinite.
TES III: Morrowind was about the best I could run and it crashed after ~15 minutes :p
This thread gave me the great idea of installing Tomb Raider 2013 on my laptop. 4 FPS is good, right?
22 minutes ago, cleb said:
Usually you want about 6 or 7 :/
Yeah I mean, it isn't ideal but it's good enough for me
Yeah definitely i got fallout 4 running on my three year old laptop with a gt 745m graphics (which has aged rather badly due to this being my first computer and all.) fallout 4 runs smoothly at 30 fps at 1080p on low to medium settings.
but GTA 5 is another story i tried, it works but is not really playable
Best rule to follow.
Ignore 'Minimum Requirements' on games.
Consider ' Recommended Requirements'  as ' Minimum Requirements' and go from there
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
That's a fair point. But sometimes you just wanna play your games at 800x600 at 20fps
https://www.youtube.com/watch?v=hi8mmNO1eZA
Lol, that's actually not too bad. Little pixely, but totally playable. :)
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
