Please Help me find a lens mount for the Helios 44-2
Solved by ShadowCaptain,
Agreed, a native mount 50mm lens would perform just as well or perhaps better.
However if you're still adamant about the Helios lens, I believe this is the adapter you need.
http://www.bhphotovideo.com/c/product/843885-REG/vello_la_cef_m42_lens_mount_adapter.html
Yep that would do it
but I think OP should get this, $50 for a 50mm F1.8 lens with AF
http://www.bhphotovideo.com/c/product/1111454-REG/yongnuo_yn50mm_50mm_ef_for_1_8.html
