Best LED air flow fans
Solved by WoodenMarker,
Riing series looks good.
TrueQuiets and Gelid Wings are great.
Would they be fine as case intakes? since the riing series is marked as sp optimized, and there isnt any restriction at the front of my case.
I know they will work fine, however would an af optimized fan like the corsair af series be better in terms of airflow?
Corsair led fans are mediocre at best. Riing's are better. Corsair's AF/SP fans with the rings are good though.
Featured Topics
RevGAM ·
Posted in Custom Loop and Exotic Cooling0 -
JakubR88 ·
Posted in Power Supplies5 -
1
2
4
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
