Writing noise from CPU?
Solved by Godlygamer23,
But as you say, now that I think about it (not that I hear electrical noise all the time) but it could be that I guess, since I have my CPU on automatic voltage use, it jumps all over the place during load and idle. But you dont think that it might be hurting my computer right? @Godlygamer23
Voltage jumping in regards to any electronic will not do anything harmful. It's supposed to happen, and occurs a lot on laptops. It's totally fine.
