those are 950's and a 960?
      CPUIntel Core i7-4790K 4.8GHz Moherboard: MSI Z97 SLI Krait Edition Memory: HyperX FURY White 24GB DDR3 1866MHz GPU: Asus GTX 970 Turbo
             PSU: EVGA SuperNOVA 750w SSD: Crucial MX200 250GB HDDWB Blue 1TB Monitor: (2x) BenQ GL2460HM 24-Inch Case: NZXT S340 White
Your link will only work for you.
there are 3 950´s on that page
http://i.imgur.com/783M6av.png
one uses less power than another? although the classified overclocks better i think because of more power going to it
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
The classified has an overbuilt PCB for extreme overclocking, while the FTW edition has a more standard PCB layout.
The cooler will be similar between the 2, so I would only get the classified if you intend to watercool/ balls to wall OC
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
links only work for you and what you have comparied
classified has better power delivery. more overclocking.
cooler is the same acx 2.0+
Here
the only difference I can see is the FTW takes less power.
correct answer would be "is able to take less power"
They are both using the same design for the cooler, but the Classified has a slightly taller cooler. So a tiny bit more surface area to cool it down.
Main difference of the cars is the power delivery as mentioned above. I would honestly just recommend the FTW+ over the Classified card. Unless the price difference is so minor, then you might as well go with the Classified.
The silicon lottery plays such a large part of overclock these days, I would not spend the extra for the classified's overbuilt PCB.
It might have the power delivery for mad overclocks, but if it flunks the silicon lottery it wont be blowing other 980 ti's out of the water or anything.
