Core temps seem low under load Xeon E5440
Solved by skateking60,
Just make sure you go through the procedure of updating/installing the new BIOS correct and that the BIOS has good reviews (comes from a reputable website) and you should be fine. If you are worried about it and the setup you have now seems to be working fine then I would say just leave it
Okay, thank you!
Featured Topics
3
bleedpurple ·
Posted in Storage Devices2 -
geoffery ·
Posted in Troubleshooting1 -
IPQ ·
Joey__ ·
Posted in Troubleshooting5 -
83y ·
Posted in Troubleshooting0
