Discussion - Cooling computers with food products (Milk, Juice, etc...)
mynameajeff
I am sure a lot of you know who JayzTwoCents is on youtube, and if you don't he is a tech reviewer kind of like linus (however he strictly does PC stuff) anywho he recently made a video benchmarking temps of his CPU while liquid cooling with Milk, Juice and powerade.
What are your opinions? What liquids would you like to see a PC cooled with?
Was this stupid and a risk of ruining hardware just for the sake of a video?
Discuss!!!!
RyanTheCanadian
Network Administration / Systems Management and Security / White Hat
My computer is the definition of scrapyard wars.
I still want to see someone use mercury to cool their computer. It would be dangerous, expensive, and heavy, but it would look fucking awesome.
Powerade's got what your computer needs, Powerade's got electrolytes.
Dubs are better than subs
Does mercury take heat all that well?
RyanTheCanadian
According to @LukaP, very well.
Still, horribly dangerous, expensive, and heavy. If there was a leak, you can kiss your components goodbye even if they aren't energized.
LIQUID HELIUM
At least you would know when you have a leak in the system, everyone in the room would start sounding like chipmunks
RyanTheCanadian
ide like to see someone cool with gallium rather than mercury
no no its colder than liquid nitrogen xD
Liquid oxygen. the results of a leak would be rather, explosive. ha ha
I am pretty sure a mercury leak would damage more than just your computer components :P
RyanTheCanadian
I would honestly like to see Isopropyl Alcohol used in a loop or 50/50 car anti-freeze fluid.
There was practically zero risk with trying out cooling with Powerade, milk, and OJ.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
well they did the worlds fastest overclock on a fx 8130 with liquid helium
8.67Ghz
AMD FX-8350|8GB DDR3|GTX750TI|2TB HDD|CX-430 PSU|
8.67Ghz
I feel like that clock speed on a AMD chip still really sucks lmao
RyanTheCanadian
vaporised alchocol isn`t really nice with electricty, eh
to game or not to game, that`s the question
True, but if it's contained inside the loop then I don't think there'd be a huge problem. What I would do is leave the reservoir as empty as possible without killing the pump so that the vapors have a place to go.
Vented reservoir?
RyanTheCanadian
No one has recommended Mountain dew yet? Wow
My Build: Phoenix
Processor: Intel i7 4770k, Motherboard: Asus Z97-P RAM: Corsair Dominator Platinum 16GB GPU: MSI GTX 1050TI OC Case: Corsair ICUE 4000X, Storage: Samsung 840 EVO 120GB + 500GB + 2TB HDD PSU: Corsair RM750, Cooling: Corsair H100i Capellix,
        If you want to talk to me or give me an answer, please tag me otherwise you'll be talking to thin air ❤️
Vented reservoir?
You could, but you'd have to refill once in a while since alcohol evaporates pretty quickly, especially when heat is applied to it.
would be really cool and risky, which makes it hella more fun
I wonder if someone will ever do a custom loop with nuclear reactor coolant xD.
Nuclear Reactors are typically cooled with river water, so it's not anything special.
Desktop: i9 11900k, 32GB DDR4, 4060 Ti 8GB 🙂
Liquid Sodium is a popular coolant in nuclear reactors. Not really usable in computers given that the metal is solid until about 150°C, by which point any CPU has died.
Liquid helium cooling would cost you somewhere in the region of 400,000 euro per year, assuming you have a closed loop and don't just vent it off.
Cooling a computer with organic substances is just going to make your computer smell of trashcan after a week. It might work for the 10 seconds that they test it in those videos, but the long-term cooling performance and the hygiene issues simply make it a non-starter.
Intel i7 5820K (4.5 GHz) | MSI X99A MPower | 32 GB Kingston HyperX Fury 2666MHz | Asus RoG STRIX GTX 1080ti OC | Samsung 951 m.2 nVME 512GB | Crucial MX200 1000GB | Western Digital Caviar Black 2000GB | Noctua NH-D15 | Fractal Define R5 | Seasonic 860 Platinum | Logitech G910 | Sennheiser 599 | Blue Yeti | Logitech G502
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
Isn't sodium super reactive with water?
RyanTheCanadian
Yes, but one would assume that the sodium does not come into contact with water. Think of it like a closed loop water cooler for your PC. The coolant never comes into contact with the air being blown through the radiators.
