No.
What connection are you currently using?
https://linustechtips.com/topic/523924-do-i-need-a-hdmi-cable/#findComment-6956365
no
https://linustechtips.com/topic/523924-do-i-need-a-hdmi-cable/#findComment-6956389
Do I need a HDMI cable if I want to watch 1080p videos?  Sorry for the newb question.
no.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/523924-do-i-need-a-hdmi-cable/#findComment-6956410
No anything that is newer than 10 years old (and some that are older) can transfer 1080p.
 Pc Speck's : i7-6700K 4.0GHz , GTX 980 Ti G1 Gaming 6GB , 16 GB Corsair Vengance DDR4 - 3400 , ROG SWIFT PG278Q 144Hz , (2) Acer G277HL bid 60Hz.
https://linustechtips.com/topic/523924-do-i-need-a-hdmi-cable/#findComment-6956501
