Advantages and Disadvantages of using a PWM "Y" Splitter
Solved by MeltingPoint,
You can control 2 or more PWM fans off a single header but you can only read the speed of one of them. Should not be an issue if they are the same fans.
Also, speeds will be different if the fans are not the same.
Featured Topics
Anonymous1234 ·
Posted in Troubleshooting1 -
CasoF13 ·
Posted in Storage Devices1 -
hanouzz ·
Posted in Power Supplies8 -
Hellowpplz ·
Posted in Troubleshooting3 -
D. Sheperd ·
CGarza ·
Posted in Servers, NAS, and Home Lab3 -
MyLittleFella ·
Posted in Audio2 -
Renton577 ·
Posted in Laptops and Pre-Built Systems1
play_circle_filled
Latest From Linus Tech Tips:
iPhones Are Undeleting Nudes?? - WAN Show May 17, 2024
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
