hi and thank you for taking the effort to read what probably may be me being impatient, but anyway, yesterdey at 7 pm i put an old notebook 250 Gb hard drive to format, i plan on using it on my pc  so i started formating it, i've got 2 partitions one of 25 gb(12%) and another of 150(2%) the left 60 is unassinged  by the time im writing this its 12 am, so its been 17 hours and so far i've got 12% and 2%, is this normal?
https://linustechtips.com/topic/521683-formatting-taking-way-too-long/
No... That seems to be an extremely long time to format a harddrive. You should have deleted the partitions first then formatted from there.
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
quick format or non quick format?
that seems a bit long even for non quick format
when it finishes run crystaldiskinfo to see if its dying and crystaldiskmark to see how fast its max speed is
there were 4 partitions, i couldnt format the others so i deleted them and got the unassinged space, but for the other 2 i just formatted it, i can cancel the format, but will it ruin the drive?
no, it isnt quick format, as i said above, if i cancel te format will the drive get damaged?
