ATX Case
Tyranade
So I am already thinking about upgrading my Newly built ITX system to full size ATX (Specs in my sig) and I am looking for a case. My upper Limit is preferably £120 (But I can go +£10-15).
Now I know a case is Highly subjective but I don't care what it looks like as long as it isn't branded with My Little Pony and it is covered in Pink, I am more of a function person.
What I need it to have is...
  • Removable HDD Cages
  • Support for the H100i in Push Pull (I know you don't usually get more performance I am saying Push-Pull so when it comes to build the system the H100i isn't right up against the top of the Motherboard)
  • Bottom Mounted PSU with support for 180mm PSUs
  • A Window
  • Dust Filtering
  • Preferably Removable ODD Bays (Although I can live without this)
  • Ample room for Cable Management
  • No fan grills on the Window
The case doesn't need to support Custom Water Cooling as I am not going to be doing that, so I don't need a case with the Rad space of the 900D I just want a case that will support an ATX Motherboard with the requirements above.
That is what I need for a case, my budget is £120 - £135
Thanks for the help.
CPU: AMD Ryzen 7950X3D | Cooler: NZXT Kraken 360 2023 Edition | Motherboard: Asus X670-P Wi-Fi |  RAM: 32GB Corsair Vengeance 6000MT/s
GPU: XFX AMD Radeon 7800XT | PSU: NZXT C1000 | Storage: Corsair MP600 Core XT 2TB | Case: NZXT H7 Flow
CPU-Z Validation
CM Storm Scout 2
With that case you need to put the fans of the H100i on the outside, I watched the Video Linus did when he was building in that case.
I just looked at the C70 as the above poster just said, and I just realized that I forgot to add, no fan grills on the window.
CPU-Z Validation
I'm not sure of the length of the h100i's tubes, but can you mount it in the front?
Edit: You don't put the fans on the outside, the rad sticks out the top, unless you're pulling.
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
It's still on the outside of the case. I'd rather it be on the inside.
CPU-Z Validation
There are 2 120mm fan slots in front that you can put the rad. I'm just not sure if there's enough length
CPU-Z Validation
