BLOWN VRM'S? NEED QUICK HELP
Solved by Hirad123,
If you blew your VRM i'm pretty sure the system would just crash, not just turn aero off. If it doesn't smell burnt or anything and you didn't see any smoke i doubt you burnt your VRM.
Featured Topics
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
2
7
1
Shane Martin ·
Posted in Displays2 -
5
INotPablo ·
Posted in CPUs, Motherboards, and Memory2 -
PatRed ·
Posted in New Builds and Planning8
