How does Coolant works?
Go to solution Solved by JebKerman,
All I've to do is go to my near market & buy distilled water ?
Pretty much, just get the concentration right/near enough. I think 1 L would be enough but  more than you need is better than less.
I've ordered all my parts . all i need is tube & coolant.
I'm just not sure how does mixing all of this works help?
So i'm planning on buying
3/8 5/8 clear tubing,primochill
I want a white mix of coolant.
Idc if I've to change it every year.
So if i where to get
http://www.performance-pcs.com/xspc-ecx-ultra-concentrate-coolant-100ml-white.html#Additional-Information
Like will i need more then 1lt for 360+240, & d5 140res?
https://linustechtips.com/topic/517909-how-does-coolant-works/
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/517909-how-does-coolant-works/#findComment-6884284
I'd just use distilled water :P
coolants come with anti-corrosives and anti-bacterial agents the later is always something you really should always add (though biocide or silver), the former is more a safeguard.
https://linustechtips.com/topic/517909-how-does-coolant-works/#findComment-6884289
use mayhems coolants only, they are the best for coloured stuff
https://linustechtips.com/topic/517909-how-does-coolant-works/#findComment-6884317
i want to try this one out In the future i'll just buy Ice dragon since my build is all white.
I'll change the coolant every 8-10 months
+  I heard with ice dragon I don't have to change it .
https://linustechtips.com/topic/517909-how-does-coolant-works/#findComment-6884335
Well this is the stuff mayhems went in collaboration with to make pastel.
https://linustechtips.com/topic/517909-how-does-coolant-works/#findComment-6884344
you always have to change any fluid every year or two
and mayhems is the best because it looks good for the longest time without clogging up your waterblocks
https://linustechtips.com/topic/517909-how-does-coolant-works/#findComment-6884382
Just be prepared for a possible colour change.
Im using premix and well its a little more transparent than i wish it was but also its been like that since the beginning.
Another alternative is Aqua computer coolant http://shop.aquacomputer.de/product_info.php?products_id=2467
Its not mayhem because the company is english and this is made in germany.
https://linustechtips.com/topic/517909-how-does-coolant-works/#findComment-6884675
Then what do you use? Im going to stick to mayhem no matter what Jay says.
I don't know the guy that owns mayhem's kinda looked like an ass on twitter... I don't even like marginally bad customer service, so I will never buy mayhem's. Like I'm all for peoples own opinions, but as soon as someone starts attacking people personally, because what they think or said. Then that's to far. I mean they were insulting jays water cooling skills saying he should stick to air, but he has been doing Liquid cooling for 7+ years, so I think he knows a thing or two...
after jayz video, don't really want to mess around with mayhems.
Its not part of mayhem. They just collaborated to make pastel.
https://linustechtips.com/topic/517909-how-does-coolant-works/#findComment-6886859
All the coloured liquids split and change colour, its the nature of the mixing in little particles into your loop that will start to lay down in low flow or restricted places. You will definitely be cleaning it out after a year along with desperately trying to clean out all your components too.
There is another way, distilled water and biocide. The biocide stops the algae growth and with nothing else in there it doesn't drop stuff in your loop. I have had distilled water loops run for 2 years without a change and no issues, because well there are no particles to cause issues. I used Thermochills coloured premix before I learnt that lesson (and the more experienced watercoolers were telling me that liquid split and I ignored them because Thermochill said they had cracked the problem!!!).
I know its going to fall on deaf ears, it has been ever since the Mayhems thing with Jayz happened and people are still recommending coloured loops. I have been watercooling my PC for 10 years, you really do ignore this advice at your own peril because I have seen every friggin scandal on these premixed liquids come and go like 5 times now. Nobody seems to learn the lesson.
https://linustechtips.com/topic/517909-how-does-coolant-works/#findComment-6887426
For me that is not a option i want style.
https://linustechtips.com/topic/517909-how-does-coolant-works/#findComment-6888981
