Does WiFi signal strength equal WiFi signal quality?
Solved by JamesThresher,
Signal Quality has nothing to do with signal strength and everything to do with Signal to Noise Ratio (SNR).
To use the music analogy that skulbringer mentioned, If you turn up the volume on a piece of music, you may be able to hear it better, but not if there were 20 other songs playing all at the same at the same volume. However you would be able to hear the music just fine even on a very low volume if everything else around you was completely silent.
the Greater the SNR, the greater the quality and therefore the performance that you (should) get. Although there are other factors that can affect this.
