Running 2 GPU's with different tasks
TRIPLE KILL!
I don't suggest using a dedicated physx card. It rarely makes a difference. Just going to add heat and power consumption.
@CALBIX
Lol my phone bugged out
Do I need an SLI bridge for this.
(I have a 1000w power supply so it does not matter)
It just ran through my head, can I use my GTX 770 as my main card and run a GTX 660 ti as a dedicated physx card or something else?
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
No you won't. You won't be SLI'ing the cards.
Having a high wattage PSU won't prevent heat.
Thank you
Yes I know having high wattage does not make a difference but trying something out in the tech world is always fun! I want to try this
Thank you
True! Best of luck.
I, and most people I know, and most people online, have had basically no positive results from dedicated physx cards in the last 5 years.
