so im have now cloned my HDD to my SSD but everytime i try to boot up using my SSD it wont work. ive changed in the BIOS so the SSD is the boot drive but it doesnt work.. Help?
How so does it not work? Does the BIOS say there is no boot device or does Windows does not work?
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826690
do a proper clean install
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826697
it says please insert boot drive or something like that,
And your BIOS does actually see the SSD?
(Maybe you shoukd just do a clean install anyways)
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826706
in the bios i can find my kingston SSD but it doesnt work, and i cant do a clean install cause then i would need a windows installation disk, right?
Watches and computers
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826710
i cant... i dont have a windows CD or whatever you need...
do you seriously not have a USB drive??
that's all you need...
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826713
oh... how do i get windows on it then?
if youre using windows 10 you just make installation media
tutorial here:http://www.howtogeek.com/224342/how-to-clean-install-windows-10/
if youre using older than windows 10 you just need to get your key with a keyfinder and download the windows ISO from microsoft
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826721
i have windows 10  but how big USB do i need? i have a 16gb
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826733
4GB at least
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826734
after i downloaded windows to my USB do i just go into bios and boot from it?
did you read the instructions in the link?
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826850
theres quite a lot of text.. i downloaded the windows thing on my usb.
yes
text is something that you read
no reading = no learning
no learning = you screw up and do stuff wrong
if you really dont want to read, just look up tutorials of "how to clean install windows 10" on youtube
maybe visual learning is better for you
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826873
yes
when the USB finished it said something about if i wanted to install it again i would need a windows key??
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826882
no, windows 10 will activate itself after installing as long as you havent changed your motherboard
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826960
on that website they say so much about different windows and methods and all.. its confusing i dont really know what to do or what to read..
https://linustechtips.com/topic/512400-ssd-help/#findComment-6826971
