OBS issues
Go to solution Solved by WereCat,
ENCODING
- Dont use CBR
- Set Max Bitrate to 1000
- Use Custom Buffer Size and set it to 0
- Quality Balance (try to play with that but start with 6 and see how it goes for you if you get good performance try to increase it)
ADVANCED
- Process Priority Class set to Normal or Above Normal (the higher the value the more resources from your CPU will go into recording)
- x264 CPU Preset set to veryfast
- Encoding Profile set to main
- Uncheck Use CFR
- Check Custom x264 Encoder Settings and type in this crf="number" ("number" the lower the number the higher the quality (set it to 20 initialy and check if you get good performance ... the higher the number the more pixelation on your recordings).
I'm having some issues with OBS, there is a lot of pixelation. Also it says it's at 30fps however it looks much more choppy.
I'm recording not streaming
Game begin recorded
   Dirty Bomb
OBS settings
Internet Speed
I usually upload videos while I sleep so as long as it doesn't take more then 8 hours I"m fine with huge file sizes.
TheGrim123321
CPU: I3-4170Cooler: Hyper TX3Mobo:Biostar B85MGMemory: G.Skill Ripjaw 2x4GBStorage: Barracuda 500GBGPU: Zotac GTX660Case: Fractal 1100PSU: Evga 500WMonitors: FHX2153L 21.5"│V193WEJb 19"Keyboard/Mouse: CMStorm DevastorAudio: MonoPrice 8323Microphone: BlueYeti BlackoutOS: MSX(Win10) Quote me or @TheGrim123321 to get my attention.
https://linustechtips.com/topic/510406-obs-issues/
You should downscale that. OR even change the CPU preset. I set mine to fast since i have a GOOD cpu COOLER. It will stress your CPU alot more. But the quality will look a lot more "clear"
"Audiophilia... when you start to hear voices in your head."
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805321
You're saving to local files? Then you should put it wayyyy higher than 1500 bitrate. Put it at like 10000
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805325
Wouldn't that make the files ungodly large
TheGrim123321
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805332
Mines on very fast
TheGrim123321
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805335
That bitrate is waaaaaaay too small.
I stream at 4500 kbit for a 720p@30fps.
When i record at 1080p@60fps you should be looking for a bitrate of around 20000 kbit/s for mid-high quality recording. Youd ont wanna go over 30000 kbit though.
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805343
I'll try out 4500, is it different for recording?
TheGrim123321
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805345
I don't think it would make *that* big of a difference
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805349
ENCODING
- Dont use CBR
ADVANCED
- Uncheck Use CFR
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805357
Of course it is, but if you plan on uploading quality footage, you need this file sizes. ive seen 1080p@60fps of up to 65Mbit/s, it is way overkill and it was the "pure" footage, once you pass a minimal encoding you can decrease that a lot.
Also, with your GTX 660 you should be able to use NVENC to record (Its Nvidia shadowplay), it will decrease the impact on performance while you record.
Edit: Also, yes, stream quality is crappy compared to recording one.
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805358
ENCODING
- Dont use CBR
ADVANCED
- Uncheck Use CFR
With those settings it's not even showing the video after it exports, just audio
TheGrim123321
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805377
Weird. I record like that with no problems. I edited my previous post with pictures. Try check it out.
EDIT:
did you have your SCENE set properly?
The scene is fine, I kept the quotes on the crf=
TheGrim123321
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805385
Oh, all right then :)
Yep, Thank you for your help :D
TheGrim123321
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805397
ENCODING
- Dont use CBR
ADVANCED
- Uncheck Use CFR
wtf, you record 1080p at 1000 bitrate?
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805440
Doesent matter when you use custom x264 encoder settings.
okay
https://linustechtips.com/topic/510406-obs-issues/#findComment-6805489
