Could someone please explain the differences in performance between 6th gen i5s and i7s? That or please direct me to a thread about it. I'm in the market for gaming laptops.
forgot to add the chips!
Intel i5-6300HQ 2.3 GHz Quad-Core
     http://www.amazon.com/gp/product/B015PYYDMQ?colid=380IHHO5BVKIU&coliid=IHDR3618838DX&ref_=wl_it_dp_o_pC_S_ttl
Intel Core i7-6500U 2.5GHz
     http://www.amazon.com/dp/B0146DD02G/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=380IHHO5BVKIU&coliid=I3ADJJZE80TSJ8&psc=1
https://linustechtips.com/topic/508026-help/
There are a lot of different i5 and i7 mobile chips which are all different. Which chips are you talking about specifically?
https://linustechtips.com/topic/508026-help/#findComment-6778273
http://www.anandtech.com/show/9582/intel-skylake-mobile-desktop-launch-architecture-analysis/8
the 15W -U processors are all 2 cores 4 threads. All of the i7 have higher core clock over all the i5.
the 28W -U processors also 2 cores 4 threads but better integrated grpahics over the 15W -U ones
the 45W -HQ processors have 4 cores all but i7 have 8 threads and i5 4 threads so the i7 is a lot more powerfull in this case (also more expensive)
https://linustechtips.com/topic/508026-help/#findComment-6778294
https://linustechtips.com/topic/508026-help/#findComment-6778319
