I am trying to play games with 3D. I'm not sure where I get the drivers for this. Can someone please link me where I get the drivers and if there are any other things I need to get. Thanks :)
do you have a 3d screen? because you cant without one
https://linustechtips.com/topic/506979-3d-vision-nvidia-help/#findComment-6766245
you have a 3d monitor?
you should just turn on 3d vision in the nvidia control panel and have it work...
the 3d drivers are part of the GPU drivers already
https://linustechtips.com/topic/506979-3d-vision-nvidia-help/#findComment-6766248
It comes with the normal Geforce Nvidia drivers.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/506979-3d-vision-nvidia-help/#findComment-6766249
Yes my monitor is an Acer GN246HL, It comes with Nvidia 3d vision and 3d lightboost
https://linustechtips.com/topic/506979-3d-vision-nvidia-help/#findComment-6766259
well 3dvision is already downloaded with your GPU drivers so you should already have it
https://linustechtips.com/topic/506979-3d-vision-nvidia-help/#findComment-6766283
Also, what is the difference between the recommended and "tested" drivers vs beta. Are the beta drivers better?
No.  Tested drivers are certified by the Windows Hardware Quality Labs, and are guaranteed to be stable.  You may get a couple extra features/optimizations with the beta driver, but it's not guaranteed to be stable.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/506979-3d-vision-nvidia-help/#findComment-6766319
Go to the Nvidia Control panel and activate it it should already be installed when you installed the drivers, if, not re-download them.
https://linustechtips.com/topic/506979-3d-vision-nvidia-help/#findComment-6766363
