I have a iPhone 5, and i want to make youtube videos with it, how can i make the camera quality better? I am jailbroken if it makes a diffrence, i want to do this through apps preferably, but lighting will work. Thanks!
Ryzen 5 1600 - GTX 980 Ti - Broke.
https://linustechtips.com/topic/505950-increase-cam-quality-on-iphone/
No not really besides from filters and stuff like that
There isn't really a way.... you can't change the sensor...
What you CAN do is ensure that your subject is well lit when recording. This will help immensely.
ESXi SysAdmin
I have more cores/threads than you...and I use them all
filters won't help, good lighting will.
There are some cases with lens on them which might help.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
What? You cannot "increase" the quality, quality is determined by the sensor and the optics - you are limited to what the camera can do
HOWEVER Download "filmic pro" its a great app, lets you choose the bitrate and recording resolution - I can actually record higher than 1080p on my iPhone 6, and can record at 50mbps
It also has loads of other good features
there might be other similar apps too
BUT - honestly the standard camera app is  like 99% of the best you can get - buy some softboxes and a tripod
I have a tripod and one studio light, but what do softboxes do exactly?
They diffuse the light
This is the best option.
If anything clip on lenses actually slightly reduce the video quality
