yeah it works great! i use it all the time for cleaning up my registry. (i wrote my own script to clean everything else so i dont use it for that anymore)
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/503592-does-ccleaner-work/#findComment-6723758
yeah just make sure that when deleting temp files you actually know what things you are selecting
if you check the wrong boxes you could delete all your desktop shortcuts, or network passwords, or a bunch of stuff you probably want to keep
but thats just for the crap cleaner part
the registry cleaner you can check all the boxes and its safe to delete
https://linustechtips.com/topic/503592-does-ccleaner-work/#findComment-6723783
It does work, but I suggest not to use the registry cleaner.
Or if you just want to play safe then Disk Cleanup would do fine.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/503592-does-ccleaner-work/#findComment-6727193
My question is very simple but I'm just wondering since I've never used it. But, does CCleaner actually work? I would love to hear your thoughts and opinions about it or experiences using it.
Yes, it can actually improve desktop performance too if your computer is too cluttered with junk
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/503592-does-ccleaner-work/#findComment-6728858
I've never had the registry cleaner actually fuck something up
You should allow it to backup the deleted keys though, just to be sure. It stores it as a .reg file, so if something stops working, you can just double click your latest backup and it'll reinstall all the keys.
"It's a taxi, it has a FARE METER."
https://linustechtips.com/topic/503592-does-ccleaner-work/#findComment-6729082
Well good for you then, my laptop was f*cked up since I used the registry cleaner. Somehow it made my laptop blue screen like hell, I don't really like registry cleaner anymore. Yeah I should've made a backup of it, well.... I just want to play safe, disk cleanup does fine as well, though CCleaner offers more features.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/503592-does-ccleaner-work/#findComment-6750819
