Best settings for GTA V
NoTrollOK
Hi,
What is the best graphics setup for my PC on constant 60FPS.
CPU:AMD FX 8320 @ 4.3Ghz
Cooled by:CM Hyper 212 Evo
RAM:KVR 4GBx2
Mobo:Asrock 990FX Extreme3
GPU:Sapphire Radeon R9 280
HDD:120GB V300 and 1TB WD Blue
PSU:Aerocool KCAS 600W
Case:Corsair Spec-01
Monitor:1080p 60Hz 5ms
Windows 10 anti-spying pro 64bit
When lives hand you lemon, suck them hard and post a selfie with it.
lowest settings.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
mix between medium and high im guessing, if you want a locked 60 then probably all low.
Lol okay.
You never mentioned which games you want to play. It is a very wide spectrum. If you want to run Dota 2, for example, you could be getting 120fps locked with all settings to the max. If you want to run Witcher 3, probably all on low. You should run an fps counter like Fraps and test for yourself, try changing one thing at a time until you achieve a good balance between fps and visual quality for a certain game.
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
I think the title pretty much had that covered >.<
Oh crap I'm sorry I was replying to a bunch of threads and I completely forgot the title. Well then, I think you could put most of the settings on High, but my original suggestion still stands: Get yourself an fps counter and experiment a bit. Turn it all the way up and see how it plays. Then lower the things that you personally find the least important. Repeat until you get a visually satisfying experience and a 60fps average.
~ Specs bellow ~
