First Blood Problems
Go to solution Solved by linusforsell,
Did you attach your forum handle? Otherwise, PM Slick.
So I log into the forums and I click the donate button. I add a credit card to PayPal and I donate $10. I even have the receipt showing I donated $10 to Linus Media Group. Did I do something wrong because it has been about a week since I donated and I don't have the First Blood Bronze Badge.
Thanks
Space is pretty awesome.
https://linustechtips.com/topic/50108-first-blood-problems/
Hmm did you really donate?
edit: I read this as first world problems xD
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/50108-first-blood-problems/#findComment-667924
Someone needs to assign the badge, when did you donate?
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/50108-first-blood-problems/#findComment-667930
I did not have an issue at all and if you didn't put your username in you'll have to contact Slick i believe he will verify info to fix it.  If they are busy it can take a while to get done as well.
Intel 4790k • Asus Z97-A • Gigabyte GTX 970 Windforce • G.Skill 1866 4GBx2 • Corsair HX850W PSU • Noctua NH-D15 Air Cooler • Intel 530 120GB SSD(OS) • 1TB HDD(Games) • Cooler Master HAF 912 • Logitech G15 Key • Razer Abyssus Mouse • Asus 24in 144hz VG248QE
https://linustechtips.com/topic/50108-first-blood-problems/#findComment-667934
Did you receive it automatically? Or did you have to wait for an admin to give it to you?
https://linustechtips.com/topic/50108-first-blood-problems/#findComment-667941
While paying, there was a box for entering your username. I did that, the badge showed up within hours.
You probably forgot that, so you should PM Slick.
I'm dutch, so feel free to correct any spelling mistakes I might make.  I try to do the best I can!
CASE: Fractal Design Define R6 MOBO: Asus ROG Maximus XI Hero (Wi-Fi) CPU: Intel Core i7-9700K GPU: Asus ROG-STRIX-GTX1080TI PSU: Corsair HX1000 V2 MEM: 64GB G.Skill Trident Z RGB 3200mhz  COOLER: be quiet! Dark Rock Pro 4 STORAGE: Samsung 970 EVO 500gb +1tb NVME / Samsung 840EVo 1tb / HGST Ultrastar 10tb
https://linustechtips.com/topic/50108-first-blood-problems/#findComment-667990
Slick has to assign them to you so if you didn't add your username you need to PM slick he will verify some info with you then get it assigned
https://linustechtips.com/topic/50108-first-blood-problems/#findComment-668000
I just donated a few mins ago and I said 'My forum name is: Cacao', it just hit me after that if it's an automated system it probably won't pick it up. Since someone is assigning them I have nothing to worry about, the OP probably just needs to wait a bit, like me.
https://linustechtips.com/topic/50108-first-blood-problems/#findComment-668015
