Difference between Rail and Dual Rail?
Solved by AresKrieger,
The Corsair RMI has a rail feature where it can be dual or single, what does this mean and when would it be useful?
Thanks.
It's basically marketing noise, its allows the PSU maker to make a more stable output without the need of as thick of wiring (which allows for more amps), or as much quality of power control, it's pretty much standard at this point for PSUs so it means nothing (that psu is good though btw but usually expensive)
