running it at 144hz
Solved by 1_thing,
GPU?
Have you tried going to the control panel and opening Displays, adjust resolution, advanced, monitor tab, and seeing from there?
(That's where I think it is anyways)
Shouldn't there be a way to overclock the monitor?
I'm sorry guys!! I did a Linus didn't look at the instructions.....
I looked at them and you boot the monitor then the PC and its all ok!!!
but thanks for replying!!
thing
Featured Topics
4
17
2
JFRStudent ·
Posted in Photography and Videography1
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
