SSDs have no moving parts inside. So no, they don't make any noises
Sorry for my low english, but I'm trying my best  ;)
| MOBO: Asus P8P67 Pro Rev 3.1 || CPU: Intel Core i7 2600K || COOLER: Thermaltake HR-02 Macho Rev. B || RAM: 2x Patriot Signature DDR3 4GB 1333MHz CL9 || GPU: Msi GeForce GTX 750 TI Oc || PSU: Ocz StealthXStream 2 600W || STORAGE: Segate Barracuda 1 TB || CASE: Corsair Carbide Series 300R |
https://linustechtips.com/topic/497483-ssd-noise/#findComment-6649565
No, beacuse they are solide state (SSD, Solid State Drive) with no moving parts.
[GUIDE] LGA 771 Mod for Dell Vostro 220 [GUIDE] LGA 775 BSEL Mod [BUILD] The Mighty Radeon-Powered Dell [VIDEO] Evolution of Intel CPUs
Can you game on an 8-year-old i7? Is the 4-year-old GTX 660 still relevant? Upgrading the HP Pro 3500
Main Rig:
CPU Intel Core i7 4930k @ 4.3GHz | Motherboard ASUS P9X79 Deluxe | RAM Hynix 32GB (8x4GB) 2133MHz CL11 | GPU Gigabyte GTX 980Ti G1 Gaming | Case NZXT Phantom 410 | Storage Samsung 850EVO 500GB, Seagate Barracuda 2TB | PSU Cooler Master G650M (650W) | Monitors x1 Dell U2515H, x2 Dell 1907FP | Cooling Noctua NH-D14 w. x2 NF-F12 iPPC-2000 PWM | Keyboard Logitech G610 ORION BROWN | Mouse Logitech Performance MX | OS Microsoft Windows 10 Pro x64
https://linustechtips.com/topic/497483-ssd-noise/#findComment-6649566
They don't have moving parts and they don't draw enough power to produce noticeable coil whine even if they had chokes or coils. So no, they don't make any noise. Unless you happen to be able to hear electrons buzzing through copper, in which case, you're probably already in hell.
https://linustechtips.com/topic/497483-ssd-noise/#findComment-6649603
I suspect that, if you can hear an SSD over any other part of your PC, it's not operating as intended.  ;)
"Well I turned the rest of my system off and then I used my fanless PSU to turn the SSD on...and it was louder than completely silent!
What the hell Samsung!?"
Yeah.
Sig under construction.
https://linustechtips.com/topic/497483-ssd-noise/#findComment-6649682
Yeah.
The psu was/would be still probably makeing the noise lol.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/497483-ssd-noise/#findComment-6649704
For all we know there are some SSDs that have their own power regulation and *might* be able to produce some coil whine.
Surface mount voltage regulators IC's are used in SSD's.
Similar to this (not what they actually use, but of similar form): http://www.ti.com/product/lp2980-n
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/497483-ssd-noise/#findComment-6654994
