DVI to DVI or VGA to VGA or DVI to HDMI
Goldeneman1
Go to solution Solved by Glenwing,
Hey guys
I got this monitor and I would like to get the GTX 960
http://www.amazon.co.uk/gp/product/B00EQ0PB5Y?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
http://www.amazon.co.uk/dp/B00SJ8FZZ0/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3M1YSKWBYE1LT&coliid=I3UD1781304TQV
I was wondering wether I should go for DVI to DVI, VGA to VGA or DVI to HDMI. Which one will bring out more quality, but will it effect performance? Also when building my PC should I plug the cable from my monitor to my graphics card or motherboard?
Thanks
DVI/DVI and DVI/HDMI will give you the same result, which is better than VGA. it will not affect performance. You should plug the cable into your graphics card.
Hey guys
Thanks
At 1080p any of those display methods will work and yield the same if not incredibly similar results- go for DVI or HDMI if possible.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
Hey guys
Thanks
