Volume icon gone?
By
Aytex
in Troubleshooting
in Troubleshooting
Solved by Goodman2265,
Try this-
-Open "Task Manager"
-End the task "Explorer.exe"
-Keep "Task Manager" open
-At the top left of "Task Manager" click "File" and then click "New task"
-Type in "Explorer.exe"
-Done!
Should fix the problem, if it doesn't I don't know what to tell you, but this usually fixes all my problems.
Featured Topics
1
ThePotatoMan1248 ·
Posted in Home Theater Equipment0 -
5
Sanedish ·
Posted in Troubleshooting0 -
joshfrog ·
Posted in General Discussion1 -
Tom1200 ·
Posted in Troubleshooting4 -
6
