Gpu load low on other games
rans
Hi,
just want to ask a question about gpu load. i notice when playing my games here. some old games are low fps compare to other old games too. for example
Assassin's creed 2 and Mafia 2.
Ac2 will go 30-50fps only (medium setting)
Mafia 2 will go 60-70fps (high setting)
so weird.. also notice that gpu load on ac2 will go upto 28% only (max) and it will not exceed.
but on Mafia 2 it will go upto 90% gpu load.
my specs are
A8 6600k
Palit super jetstream gtx 960
8GB kinston 1867mhz
f2a68hm-s1 mobo
and a 650W rise psu.
Try putting up higher settings, sometimes GPU's react oddly unless they're being given a heavy load.
Ive tried that but it gives me less fps
If a recall correctly your CPU isn't powerful at all and may be bottle-necking your 960
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
Try oc the cpu. See if it helps
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Is it possible that itl bottleneck on some games? and itl also work for some games?
not so sure if this will work cause my cpu clock is already at 4.2mhz
but il giv it a try
Some games require a more powerful CPU and others don't need a powerful CPU...It all depends on the game :/
