Hahahahahhahahahahahahahhahahahahahahahahahahahahaha...............!
No.
EDIT: We can't give you a yes or no answer on this. Look up GPU comparisons for a graphics card you're interested in. There are plenty on YouTube so... take your pick.
CPU: Intel Core i5-4460; MOBO: ASRock H97M-PRO4; RAM: 8GB G.Skill DDR3 @ 1600MHz; SSD: A-Data SP600 128GB; HDD: Seagate Barracuda 1TB; GPU: Sapphire Nitro R9 380 4GB; PSU: Seasonic G Series 550W; Case: Thermaltake Core V21 w/ AF140 blue LED fan (exhaust); Monitor: Acer H226HQLBid 21.5" 60Hz 5ms IPS (GTG) HDMI
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6585896
depends on the gpu ......
This ^
The recent AMD cards aren't as hot as they once were. - There were also some really hot Nvidia cards.
The temperature on both isn't really an issue if you buy an aftermarket cooler card, even without one they're pretty good.
Get the one that you want ( in your price range) with the features you want.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6585902
Maxwell has a rather efficient architecture leading to lower temperatures, thats what theyre referring to.
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6585917
Usually people who automatically say "Go for Nvidia for cooler temps" generally don't know what they're talking about. They're the same people who will go onto Nvidia's Facebook page and act like anything Nvidia posts is a gift from god.
AMD has vendors that offer excellent cooling solutions. Yes, Radeon cards run hotter than Nvidia cards most of the time, and yes their reference coolers are absolute garbage. But that does not mean there aren't good coolers from different vendors like Sapphire that can keep the cards under control.
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6585922
not necessarily cooler temps
AMD cards do have a higher TDP, use more power, and create more heat, but if you have a beefy aftermarket cooler you can get lower temps than an nvidia card with a mediocre cooler
when comparing the exact same cooler and cards with similar performance yes the nvidia card will run cooler, but usually AMD cards have larger aftermarket coolers to compensate for that
even without a larger cooler, the temperature is only a few degrees difference, not a big issue unless you have some restricted case airflow
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6585956
Nvidia cards run hot as balls. At least my EVGA GTX 980 does, and my case has good airflow. It even has an aftermarket cooler on it and it still pumps out heat like no tomorrow.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6585975
It's not necessarily true.
Off topic, but in Anandtech's tests, the 970 is faster than the 390 in the games that I play.
Finally a bench test I can agree with. I run at 60c with my 390 tops playing Fallout. It's usually in the 50's.
The 970/390 thing is getting kind of old. FPS don't mean shit if you have dips.
If anyone asks you never saw me.
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6585984
What is your case?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6586843
why my R9 280 was new and not broken it maxed at 68*C with 37% fan speed and averaged 65*C - now it's maxing at 75*C @ 40% fan speed since it's going to die at some point
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6587113
Exchanged my MSI 390 for a MSI 970 today, i could have just been unlucky ofc but my 390 would hit 80 during gaming and 85 while running valley, that was with the fans running at 50-60% which to me was just too loud and too hot.
I wouldnt say that the 970 runs much cooler, i dont have my 970 yet so cant talk from personal experience, but the 970 seems to run wee a bit cooler overall, but the most important thing i was looking for was a silent card, the 390 from msi had to run quite a lot faster to keep the card cool, rpm and fanspeed differ more than i thought from card to card.
For example the 290 im borrowing right now at idle runs the fans at 20% which equals 1200rpm, my friends msi 970 while gaming reaches around 50% fanspeed which is only 1100rpm on that card apparently.
Ryzen 7 3700x, MSI B450 Tomahawk MAX, 16GB Ballistix Elite 3600MHz, MSI RTX 2070 Super Gaming X Trio, Corsair RM750x V2
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6587567
50% fan speed at 1100RPM is lower quality motors usually - companies cheap out where they can
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6587737
The fans on the club3d card im borrowing right now seems alot cheaper than the msi ones tho, as long as i can get a card that runs decently cool at low rpm im hapoy :)
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6587844
cheap motors = lower RPM = more noise = Gigabyte
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6587854
Of the 970 cards, the MSI just seemed like the best choice overall, i would imagine the fans on it are near identical to the 390 i returned, just needs to work a little less :)
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6587960
What is your case?
C70. 9 fans. 1 140mm and 1 120mm SP intake fans top front in push pull over the cage. 1 120mm AF intake fan bottom front. 1 140mm SP intake in the bottom. 1 120mm AF exhaust fan in the back. 4 120mm SP exhaust fans in the top in push pull over the radiator.
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6588001
So the Gigabyte card is noisy? :) I were pretty much looking for the best combo of performance vs noise, the MSI still seemed like the best choice, dont like the fact that it doesnt have a backplate, but i guess i can always buy a custom one if i really want that.
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6588866
the 970 doesn't have one? Is it only on the 380/390? Odd - I guess the cooler on those is beefier.
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6588888
Nope, not sure why, but i guess they thought the 970 and 980 didnt need one. You can get custom made ones like this http://www.coldzero.eu/msi-gtx-970-gaming-pcb-11/2000-msi-gtx-970-gaming-pcb-11-layout-3-1.html, but rather pricy.
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6589012
As I was suspecting - they cut-down the 970 cooler or rather, beefed up the 390 cooler. If my assumption/theory is correct then expect the same level of noise as a working (I am 99% sure you had dry fan bearings on the 390) 390.
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6589024
Could be, my 390 just ran really hot and therefor had ramp up the fans quite a lot, i could keep the card at 75 under load with the fans at 70%  :lol:
Not sure about the db meter, but my 390 at 50% fanspeed sounded like this one does at 100%
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6589294
did you try undervolting it?
https://linustechtips.com/topic/491214-nvidia-for-cooler-temps/#findComment-6589538
