3 monitor setup question
Overkilled
Working out the money I'd likely get fr Christmas I've been looking at some cheaper monitors specifically a asus slim bezel without display port. Would I be able to run with 2x display port to hdmi and 1x hdmi or 1x display port to hdmi 1xhdmi 1xdvi?
AMD or Nvidia gpu?
If it's with your HOF 780 you can basically use any set of ports you like without the need for DP.
I've got a 970 hof do the same rules apply?
Yep I believe it was unless your going for 3D monitors and surround you must use DP but nowadays any of three ports will work with regular surround.
If you are going to use dport to dvi adapters, please get quality ones. Shite ones that fit poorly will piss anyone off real quick when the slightest bump disconnects the cable.
