It would be functional but it would definitely look better if you had 2 of the same monitor instead of mixing and matching
https://linustechtips.com/topic/486386-monitor-settup/#findComment-6527445
Agreed, the monitor OP already has would look really nice next to itself because of the small bezels
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/486386-monitor-settup/#findComment-6527455
ik but the problem is the price ... I need to fit a monitor and HDD into a $200 budget
https://linustechtips.com/topic/486386-monitor-settup/#findComment-6527464
don't cheap out on your monitor man (unless its like $20), you'll regret it later. remember you look at and use this thing every day, invest in a good monitor and itll last you years and years.
pc specs: 4 function calculator / 8 digit lcd display / colored numeric and function buttons
https://linustechtips.com/topic/486386-monitor-settup/#findComment-6527590
