folding power cost ?
Go to solution Solved by Enderman,
yeah its right
ok so my rig is in my sig, i limit my gpu to 65 degrees while folding which makes it throttle a little so lets say the system is using 300 watts while folding, if i fold for 3 hours at 300 watts thats 0.9KWh
my hydro price is 8.3 cents per KWh so does that mean folding for 3 hours costs about 8 cents ?   i usually fold on off peak hours and my parents were complaining about the power bill but could this be because of the folding cause really lets say i fold for 6 hours in the week that only 16 cents.... are my calculations right here ? or am i missing something ?
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/486299-folding-power-cost/
yeah its right
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6526146
yeah its right
well i guess folding doesnt cost too much then :/ guess folding will become a regular thing for me again
and a car thread !
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6526172
yeah its right
btw can you fold on a 9600gt ? might pickup a cheap system and he has one laying around wondering if i should get it to fold
and a car thread !
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6526186
no idea, i dont fold
but probably, i know people fold on crappy 10 years old laptops...lol
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6526249
lol im stil wondering if i should buy it, the guy wants to give me 4 oloder pc`s running windows xp and that have 1-2gb of ram for 50$ but one of them has windows 7 but it wont boot into windows and it has 1 gb of ram and a 80gb hdd, so i dont know if ill be able to make profit selling them fixed up or not, might buiy 2 and put all the good parts in one and sell the other parts
and a car thread !
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6526275
ok so my rig is in my sig, i limit my gpu to 65 degrees while folding which makes it throttle a little so lets say its using 300 watts while folding, if i fold for 3 hours at 300 watts thats 0.9KWh
No way the GPU is using 300w. AT ALL. My Gtx 970 Windforce, with fans at 78% reaches 80ºC when using 220w, you'd have to have a custom loop to achieve 300w at 65ºC. Maybe total system power consumption, yeah, but as far as GPU.... it's not using 300w.
Grab yourself a wattimeter (commonly know as "kill-a-watt") and plug your PC to it. Take the delta between how much power the PC normally uses and how much it uses when folding; multiply that by the time spent folding and the tax, and you'll get yourself an accurate number.
Oh, and a hint
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6526404
Oh, and a hint
i never said my gpu was using 300w.... i said whole system.... "ok so my rig is in my sig, i limit my gpu to 65 degrees while folding which makes it throttle a little so lets say its using 300 watts while folding" i said im using the pc in my sig which i limit my gpu so it should use around 300 watts by "it" i mean the whole system
and a car thread !
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6526486
Well you can see how that was unclear though and could have referred to either the GPU or your whole system
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6526565
i wouldl'nt fold on a 9600gt , because there are systems that are so much more energy efficien.
Personnally i would try to find something newer that will give you more poerformance/watt , even if it costs you more at the beginning.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6529970
Oh, and a hint
Bro I think u eitherlive in the desert or ur card has no thermal paste (Im joking ofcourse there is no way that could be it) how can u get the 970 at 78% fan speed still rise up to 80 degrees C my 770 overvolted and Oced to 1297 Mhz while folding at 30% fan speed gets up to about 65-70 degrees and thats with an ambient temperature of about 28 C (I know thats alot but I keep my pc running with the windows closed) and the 970 is far more power efficient
CPU: R7 5800x -- Mobo: Gigabyte B550 Gaming X v2 -- RAM: 2x16GB Kingston Fury Renegade -- GPU: Asrock RX 6800 XT Phantom Gaming OC -- Case: Fractal Design North Walnut/Black Mesh -- Storage: 2TB 970 Evo Plus, 4TB NM790 -- PSU: BeQuiet Pure Power 11 Platinum 650w -- Displays: AOC AGON  AG352UCG, Dell Ultrasharp U2715H -- Cooling: Noctua NH-D14 -- Mouse: Corsair M65 -- Keyboard: Func KB 460 MX Blue -- Sound: Motu M2 -> THX 789 -> DT880 600Ω -- Mic: RØDE NT1-A
RIG 2: Intel i5-8400, 16 GB RAM, RTX 2070S
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6531813
Problem isn't ambient temps or thermal paste.
The problem is actually the apps I use, which consume MUCH more power than the majority of things out there. They consume a lot more than regular apps, such as games and folding, these are relatively light programs.
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6532174
Are you sure it's not the 35 ºC temps you proclaim in your location? :)
If not, I'm curious now... what could be doing that!?
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6536086
Well, 35º happens during peak summer. It's still a month or 2 away from happening, my guess is around 25º now. At any rate, such high load is achieved with primality testing on a newly optimized app, released just a little while ago.
As a quick explanation as to why it generates so much heat,
it's because the new app uses Single Precision digits, which is Maxwell's strong point. As such, it can leverage every single drop of performance; while every other GPU had it's performance drop to around 1/3 of the older app, Maxwell actually had in increase by around 20~30%. And that's not all: those tasks are EXTREMELY memory bandwidth demanding (it's different than memory size!), which also generates a lot of heat normally absent from games and stress tests, for these aren't as demanding on this aspect. Couple that with the fact that the PC runs 24/7, so the GPU and case (and even the room, to an extent) have enough time to get heat soaked, and you've got yourself a recipe for disaster...
Oh, and remember physics: being "efficient" just means a great performance / consumption value, not necessarely "low power consumption". And if the card consumes loads of power, it WILL get hot, there's just no way around it.....
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6536195
We get a couple days like that in summer as well, usually, but that doesn't mean you have to let the room get that hot; air conditioning :)
Also, I'm lovin' the -5 - +10 range right now :D
Ah, ok that makes total sense.
of course :)
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6536295
You're lucky, I pay about 26 cents per kWh...
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6538025
mine is 8.3 off peak 12.8 mid and 17.5 on peak so ya I guess that pretty good
and a car thread !
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6539155
When in a stress test my 770 doesn't go over the 75 degrees C so I have no clue what ur are trying to explain here I must be poor airflow then
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6541502
Did you read the explanation?  He's using apps that are setup to work the card in a way that produces more heat than most due to how they can leverage more of it's abilities.  Not unlike prime95 in a way, I suppose.
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6544669
I did read the explanation but why would u ever wanna do something like that and tell people its inpossible for there cards to run that cool underload without telling anyone at first hand that he's using those programmes
https://linustechtips.com/topic/486299-folding-power-cost/#findComment-6551692
