Hey guys
I recently bought 4x 4TB HDDs and installed them. The max volume size I can get out of it is around 7TB. I only have 4GB of memory which is defiantly not enough, just wondering if that's why freenas wont allow me to have more than 7TB or that's what happeneds with using RaidZ2. I was hoping to get around 12TB, just need to know before I go and buy a heap of memory
Thanks
Ian
https://linustechtips.com/topic/484430-freenas-16tb-problems/
General rule of thumb is 1GB of RAM per 1TB of space. My FreeNAS server has 4GB of RAM, ~3.5GB of which is accessible to the system - I have 2TB of space and I am very close to running out of RAM.
Edited by Godlygamer23
https://linustechtips.com/topic/484430-freenas-16tb-problems/#findComment-6497922
Hey guys
Thanks
Ian
Can I get a bit of clarification?
Are you running your 4x 4TB in a RAIDZ2?
RAIDZ2 is equivalent to RAID6.
That means: 2 drives are Data Drives, 2 drives are Parity Drives.
You're only getting ~8TB of usable space.
If you want 12TB of usable space, you need to do RAIDZ or RAIDZ1.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/484430-freenas-16tb-problems/#findComment-6498181
Bingo.
Nothing to see here. Everything is as it should be.
Side note; GET MORE RAM. The consensus is really that you should have a MINIMUM of 8GB, regardless of how much storage you have.
https://linustechtips.com/topic/484430-freenas-16tb-problems/#findComment-6499340
Like dalek said, RAIDZ2 is basically raid 6. You have 4 drives, splits them into 2 groups of 2. in each group, it forms what is basically a raid 1 with 2 disks. It then takes those 2 groups and forms what would be a raid0. So you get parity + striping.
My native language is C++
https://linustechtips.com/topic/484430-freenas-16tb-problems/#findComment-6499957
