Phone Audio Suck
Im currently using a Lumia 735 and the build in audio suck and will always have a hiss sound when playing music or sound . I need a solution . I've tried a portable DAC only to find out that Windows phone won't work with micro usb output for music . Since I'm using Spotify , I don't think a DAP will work ( and its all very expensive , but mainly that I use spotify to stream music ) .. So what are my choices left .. get a new phone?
https://linustechtips.com/topic/483576-phone-audio-suck/
Get decent headphones?
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/483576-phone-audio-suck/#findComment-6486806
Well built in audio (not build in) suggest the speaker phone.  But I am ASSUMING you're talking about the 3.5mm jack?  If that is the case make sure you get some good headphones.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/483576-phone-audio-suck/#findComment-6486814
It isn't necessarily the headphone audio- some phones just have plain terrible audio output from the 3.5mm because of how awful the amp is.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/483576-phone-audio-suck/#findComment-6486830
Ah I thought you were talking about the built in speakers, not the 3.5mm jack. Yea if you want better audio either get a new phone or an iPod or something
https://linustechtips.com/topic/483576-phone-audio-suck/#findComment-6486839
