I currently have a big monster of a PC case and am now looking to downside to the smallest i can get! The only things i will be taking from the PC will be the MSI AMD R9 380 which is 270mm long, I7 intel core 4790k and a 3.5 inch hard drive! If you could recommend a mini case that will fit these three components that would be great! I will be buying a new motherboard and power supply to fit in the case! no price range!
https://linustechtips.com/topic/483003-smallest-possible-pc-case/
silverstone rvz02
ncase m1
now looking to downsize to the smallest i can get!
Did I win?  :lol:
In all seriousness, you might want to check out the case that @LinusTech built into here.
TheRedDragon    |i7-5820k (4.2Ghz) || MSI X99S SLI Plus || Crucial 2x8gb 2133hmz DDR4 || MSI GeForce GTX 980Ti 6Gb || Sandisk 128Gb SSD || Seagate Barracuda 3Tb |EVGA 1000W 80+ Pltnm ||
dossium.net >
Posts that won the internet - Verticle Mice
That's called the SG13. The SG05 actually is smaller.
I just figured that maybe they'd be interested in watching @LinusTech struggle/defeat the tiny form, and might like the case/get ideas,
True though, thanks for the clarification.
dossium.net >
