Hello there i live in India, I am looking for a case.
My budget is $50 (If anybody knows the Indian market my budget is Rs 5500)
My requirements are that it should have a windowed side panel and If possible 1 USB 3.0 as i will be using the case for any build in the future.
I would also like suggestions of the case which comes with a PSU preloaded, as i do not require an expensive psu for my rig.
My rig
Intel Core 2 Quad Q6600 2.4Ghz
2GB Kingston Ram DDR2 667 MHz
Intel DG33FB Motherboard
2TB Seagate Green Drive
400W Power Supply
Zotac Geforce GT 630 2gb Synergy Edition
Please suggest me some cases
https://linustechtips.com/topic/48071-best-case-for-50/
I know you are here for a case but wouldn't an apu be a better solution than what you there?
Sony Vaio Pro 13 CPU:Haswell Core i5 4200U RAM: 4 GB GPU: HD4400 Storage: SSD Pci-e 128GB (Its really fast), External 1TB Seagate Expansion Drive Weight: 1.06kg (made of carbon fiber)
Phone: Samsung Galaxy Note 2 (4.4.2 Omnirom)
https://linustechtips.com/topic/48071-best-case-for-50/#findComment-638455
no it is running at stock.
but i want to over clock it
But dont know how to do it
So you already have the rig, i thought you were planing it that's why i asked for the apu :P my bad
https://linustechtips.com/topic/48071-best-case-for-50/#findComment-638541
I assembled this pc in Feb 2008
and upgraded the GPU last year
I am from India too, would you agree that we are very behind on tech compared to other countries?
https://linustechtips.com/topic/48071-best-case-for-50/#findComment-638602
I would not say tech, as you and i both have the same phone.
But rather say that the prices of many electronics such as computers are way more than other countries because of the high rate of Import duty on electronics.
But i have ordered this laptop from amazon.com on 3rd aug 2013 and it will reach day after tomorrow to me and it cost me Rs. 20000 duty on this laptop to enter India
http://www.msimobile.com/level3_productpage.aspx?cid=6&id=401
https://linustechtips.com/topic/48071-best-case-for-50/#findComment-638706
