First Build, any suggestions?
Go to solution Solved by Kenji the Uke,
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($172.89 @ OutletPC)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($76.98 @ Newegg)
Video Card: MSI Radeon R9 390 8GB Video Card  ($309.98 @ SuperBiiz)
Case: Corsair 200R ATX Mid Tower Case  ($47.99 @ Micro Center)
Total: $822.40
Generated by PCPartPicker 2015-11-05 07:59 EST-0500
I support this build^
Want suggestions for a PC build that can run most of the current games max settings at 1080p. How big of a budget do I need? (I'm personally wanting the budget to stay between 500USD - 750USD if possible, but if needed can go higher). Would like a Blue/Black or a Red/Black themed build... Thanks for any suggestion!
https://linustechtips.com/topic/479449-first-build-any-suggestions/
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  ($213.89 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.89 @ OutletPC)
Video Card: Gigabyte Radeon R9 390 8GB Video Card  ($299.99 @ SuperBiiz)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($37.99 @ Micro Center)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($61.99 @ SuperBiiz)
Total: $764.53
Generated by PCPartPicker 2015-11-05 07:24 EST-0500
A bit over budget buuuut :3
Moist
Thank you for the suggestion. I can deal with the budget since it's no that over what I plan :3
This would perform a bit better, you have an SSD, a better power supply, a better CPU cooler than the stock one, and a more powerful graphics card, what you sacrifice is 6% slower CPU, that won't change a thing in gaming ^^ @SkittlesLover69
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard  ($49.89 @ OutletPC)
Memory: Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600 Memory  ($34.99 @ Amazon)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($44.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($51.88 @ OutletPC)
Video Card: Sapphire Radeon R9 290X 4GB Tri-X Video Card  ($323.98 @ Newegg)
Case: Cooler Master Elite 430 ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $800.59
Generated by PCPartPicker 2015-11-05 07:33 EST-0500
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
Thanks for the suggestion! :3 Why go with the 290x over the 390?
Other than the GPU difference, SSD and a better CPU cooler won't really yield big gaming boosts...
i5 4670k | Noctua NH0-U12S | Asus Z97M Plus | Kingston HyperX Fury 8gb | Palit GTX 980 Ti Super Jetstream 6G | Samsung 850 EVO 250gb
WD Caviar Blue 1tb | Seasonic M12II 850W | Fractal Design Define R5 | Dell U3014 1600p 30" 60Hz
Corsair K65 | Razer Orochi | Bose QuietComfort 15 | Creative SBS A350 2.1
Total: $822.40
CPU:Intel Core i3 3210 Mobo:MSI B75MA-E33  GPU:Intel 2500 HD Graphics  SSD:Adata SP600 128gb  HDD:Seagate 1tb 7200rpm
PSU:Corsair CX430   Case:Antec ASK4000bU3  Monitor:Dell S2240l 21.5 inch 1080p
It would give better loadtimes.. Is OP @SkittlesLover69 willing to bump up their budget enough to get an ssd as well? :3
Moist
The r9 390 does outperform the r9 290x in some games.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Total: $822.40
Moist
What about the RAM. Why not bump it up to 16GB? Is that worth it?
Just get it later. I have 8GB of ram right now and I am playing BF4 at 1600p, 2x MSAA, Ultra and I'm getting at least 68 fps but normally 85 fps :)
