CE420
thickness does not give as big a performance improvement as size does
https://linustechtips.com/topic/476980-what-will-perform-better/#findComment-6391378
CE420
Lol it isn't even close as well.
Not only does a 420 mm rad have 40% more surface area over a 360, but it also uses fans that can blow up to 2x the amount of air at the same noise.
Hell similar thickness 280mm rads often out-preform 360 rads for that reason.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/476980-what-will-perform-better/#findComment-6391393
@Enderman
@Curufinwe_wins
Thanks for the quick reply! You guys are awsome.  :D
Althought i raised another question: 3x140mm fans fit in the front of the Define s. But in the specifications listed at the website there is no support for a 420 radiator in the front. Is this because of the tubing sticking out? Is it possible if i mod the case without changing the aesthetics at the outside? Has anyone done it before?
https://linustechtips.com/topic/476980-what-will-perform-better/#findComment-6393544
